SHEFFIELD UK · AEROSPACE & DEFENCE · UK MOD APPROVED
AEROSPACE
LASER MARKING
Permanent part identification and traceability marking for aerospace and defence components. Titanium, Inconel, stainless steel, aluminium and composites — to the standards your sector demands.
660K
Parts Marked for UK MoD
25+
Years Aerospace Experience
In
Inconel Capable
Ti
Titanium Specialist
MARKING AEROSPACE
& DEFENCE PARTS
Aerospace and defence laser marking demands accuracy, permanence and traceability. Every component in an aircraft or defence system must be identifiable throughout its entire service life — often decades.
Neolase Dynamics has extensive experience marking aerospace components in titanium, Inconel, stainless steel, aluminium alloys and composites. Our largest single job was 660,000 parts for the UK Ministry of Defence — a programme that demanded consistency, security and zero errors across the full production run.
We produce permanent serial numbers, part numbers, Data Matrix codes, NATO stock numbers and manufacturer codes to aerospace standards.
  • Serial numbers and part numbers to AMS, MIL-SPEC standards
  • NATO Stock Numbers (NSN) and CAGE codes
  • Data Matrix and 2D barcode marking
  • Titanium alloy marking (Ti-6Al-4V and variants)
  • Inconel and superalloy marking
  • Aluminium alloy marking (2024, 7075 series)
  • Carbon fibre composite marking
  • Marks that survive extreme temperature, vibration and fluid exposure
laser marking aircraft grade stainless steel aerospace Sheffield
laser marking titanium medical part Sheffield laser marking inconel aerospace component Sheffield UK
660,000 PARTS FOR THE UK MOD
Our largest single programme was 660,000 components for the UK Ministry of Defence. If your defence contract requires volume laser marking with consistent quality and full traceability, talk to us — we've done it at scale.
DISCUSS YOUR PROGRAMME
MATERIALS
WE MARK
TITANIUM ALLOYS
Ti-6Al-4V and other aerospace grades. Colour marking achievable. Permanent marks unaffected by heat treatment or anodising.
INCONEL
High-nickel superalloys used in turbine components and exhaust systems. Laser marking produces legible, permanent marks on these notoriously difficult materials.
ALUMINIUM ALLOYS
2024, 7075, 6061 and other aerospace aluminium grades. High contrast marking for serialisation and identification.
STAINLESS STEEL
Aircraft-grade stainless including 17-4 PH. Permanent marking for fasteners, brackets, structural parts and fittings.
COMPOSITES
Carbon fibre reinforced polymer (CFRP) and other composites. Precise marking without delamination or heat damage.
HASTELLOY & OTHERS
Hastelloy, zirconium, cobalt alloys, niobium — we mark exotic aerospace and nuclear-grade materials that others won't attempt.
FULL PART
TRACEABILITY
Aerospace and defence programmes require full part traceability from manufacture through service and maintenance. Laser marking is the preferred method because it is permanent, non-contact, and leaves no residue or weakening of the substrate.
We produce Data Matrix codes that meet ISO/IEC 16022 and can be read by handheld scanners even after years of surface exposure. Serial numbers, batch codes, date codes and custom identifiers are all within our capability.
All aerospace jobs are handled with full security and confidentiality. NDAs are available on request.
  • Data Matrix codes (ISO/IEC 16022)
  • NATO Stock Numbers and CAGE codes
  • Manufacturer and date codes
  • Human-readable and machine-readable marking
  • Marks survive temperature extremes, fluids and vibration
  • Confidential handling — NDA available
  • Documented job records on request
AEROSPACE &
DEFENCE ENQUIRY
Volume marking programmes or single precision parts — tell us your standard, material and requirement. We respond within 24 hours.
Phone: +44 (0) 7557 278 390
Email: contact@neolase.co.uk
★ SECURE HANDLING · NDA AVAILABLE · FREE SAMPLE MARKING
AEROSPACE ENQUIRY
